Hello, locationGPS, wwbusch aka Buwo, Fernando Brochetto
Sorry for a delayed reply!
Unfortunately we do not have data filtration based on geofences. But you could use digital sensor "Private mode" instead. https://docs.pro.transcontrol.ru/en/hosting/cms/ … es#digital.
It has property "Do not show unit location" https://docs.pro.transcontrol.ru/en/hosting/cms/ … sors/props. With such sensor (if it is enabled) all messages, created while the sensor is enabled, are displayed without GPS coordinates. Works for new messages only.
Another option is to delete messages. But the last message with the coordinates could not be deleted. But if the first message is from China and the second is from Minsk (or your test location) - then you could delete the first one.
Third option is that you could communicate with the tracker's manufacture team so that they provide you with the "clean" tracker.
Hope it helps
Please let me know if there are any other questions. Thank you!
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
