Тема: Searching units that contain an asterisk in their name
Good afternoon, i wanted to see if you could help me with something i can't figure it out yet.
Im trying to make a search for a unit by it's name, i used the API "core_search_items" and it works really good, the problem or my setback its when im trying to search a unit that has an asterisk in it's name like "Unit-24**" and since i have another unit called just "Unit-24" the API shows me that unit first and at the bottom the one with asterisks.
Also when i try to show the Unit info through php API the same case, just shows me the one without the asterisks and nothing else.
Is there a way for the API to recognize the asterisks and not "skip" them.
Here's an example of how i do it:
"hst-api.pro.transcontrol.ru/wialon/ajax.html?svc=core/search_items¶ms={"spec":{"itemsType":"avl_unit","propName":"sys_name","propValueMask":"*Truck-80***","sortType":"sys_name"},"force":1,"flags":1439,"from":0,"to":0}&sid="my sid"
The unit name needs to be encapsulated by 2 asterisks in order to be read
Thank you, and any help is appreciated.
