WiaTag notification buttery level and GPS off
Тема: WiaTag notification buttery level and GPS off
We use wiatag for new clients . .  The employees have been given an Android tablet to use as Wiatag.
The employee sometimes turns off the GPS signal
Sometimes it says the battery is discharged.
The official wants notifications about the GPS off and also when the battery charge reaches 20%.
Can you please explain  how I created this notification and we need to show the battery online in monitoring screen
(06/05/2021 23:36:08 отредактировано hasan.ahmed)
Re: WiaTag notification buttery level and GPS off
wiatag sends battery level
the parameter is b
Location status parameter is (ls)
attaching wlp files
the is will only sends the value when the state of gps change
but you have to activate those parameters in the wiatag to make it end them
regards
Иконка вложений Tab 4 (1).wlp 723 b, файл был скачан 356 раз(а)
dear  Hassan . Thank you very much for your cooperation and support for me with the file wlp. It has helped me a lot .
thank you
Good morning members my request goes to wialon App tech if you can help upgrade on Wialon App On the issue of play back future,
kindly if it's possible add that future to the app, it will add more value to the app and help us also on the market ,
Because we have some competitor who are using it as advantage to take away some of our clients because of that,
And remember we have that future on the laptop users only.
Thanks.
hasan.ahmed пишет:
wiatag
Dear Hasan .
can you suggest option for Report Template  for Wiatag App . if n employees cloth GPS ( connection lost from App .
I need to make control via report
check attachment
regards
  • WiaTag notification buttery level and GPS off
you can configure these devices remotely now, and one of the options is you can controll the holder of the wiatag and disable the ability to turn of the tracking in the app.
and if he said i want to turn it off after working hours to stop consuming charge from the phone, well you can set a working schedual
the link to configure the device is
http://configurator.pro.transcontrol.ru/config
as for reports i will check and update you
Regards
Thank you Hasan for your useful information
