Application on PHP&MySQL + Wialon
Тема: Application on PHP&MySQL + Wialon
Hi all,
I consider possibility to use  Wialon system, and to integrate it into my application based on PHP and MySQL.
If I understand correctly, I need account on Wialon system, (e.g.  Wialon Logistics), and to tie it with my application. After that, I should send data (e.g.  type of vehicle) to Wialon, and finally, I should receive position of vehicle presented on Wialon map.
I'm wondering is it necessary to have same database structure on Wialon system as structure on my system?
On what way i achieve data from Wialon system in order to manipulate with relevant data (e.g. about driver or truck position)?
Thanks
Re: Application on PHP&MySQL + Wialon
Blazo,
first you need to get an account in Wialon Hosting.
than create a unit for testing and use WiaTag to send some data...
Than go to http://sdk.pro.transcontrol.ru/ and choose your programming language.
A great start is also http://sdk.pro.transcontrol.ru/playground
The SDK really provide ALL thinks you need to create / connect your own applications.
Wolf.
Thank you Wolf. I will continue researching Wialon SDK.
Hola que tal buen dia! soy tengo un problema quisiera saber como me puedo conectar al servidor de wialon si ya tengo una cuenta wialon hosting y poder asi tomar informacion que necesito?
muchas gracias
ontrack.systems пишет:
muchas gracias
Mira este topico.
https://forum.gurtam.com/viewtopic.php?id=6768
