UniqueID
(24/09/2015 19:00:16 отредактировано Desarrollo)
Тема: UniqueID
Hello.
I'm working with JAVA API to get Unit's and its properties (UniqueId, Phonenumber), somebody know how to get it?  I don't know if i have to set a DataFlag.
I hope your comments.  Thanks!
  • UniqueID
UniqueID
Re: UniqueID
Hello. Please see examples here or on the GitHub.
Mobile Development
UniqueID
Re: UniqueID
Hello Kopa!
Thanks for help me in other post.
I'm using this dataflag to get data unit (Name, customfields, UniqueId, phonenumber)
Item.dataFlag.base.getValue() | Item.dataFlag.customFields.getValue() | Item.accessFlag.editImage.getValue()
Before that delivery the new update system i can get it, but today only gets null data.
Can you tell me what is the dataflag that give the UniqueId and phonenumber??
Thanks!
UniqueID
Re: UniqueID
Hello Guys!
I'm deploy with JAVA API and i have a question, What is the dataflag that i need to get UniqueId, phonenumber1 and 2 ? , before the new update i used
Item.dataFlag.base.getValue() | Item.dataFlag.customFields.getValue() |Item.accessFlag.editImage.getValue()
Thoses apply correctly, but now only i have null data.
Thanks in advance!
UniqueID
Re: UniqueID
Desarrollo Hello. You can get unit's unique id and phone number by Unit.dataFlag.restricted data flag.
Mobile Development
UniqueID
(07/10/2015 23:41:45 отредактировано Desarrollo)
Re: UniqueID
Hello kopa.
I use this dataFlag but i can't get data Unit. I don't know if this is an error because i'm trying with all dataFlags sad
Thanks!
UniqueID
(07/10/2015 23:55:43 отредактировано Desarrollo)
Re: UniqueID
Here is the code
  • UniqueID
UniqueID
Re: UniqueID
Desarrollo Please check access type for token, which you use.
Parameter access type
Value    Description
0x100    online tracking
0x200    view access to most data
0x400    modification of non-sensitive data
0x800    modification of sensitive data
0x1000    modification of critical data, including messages deletion
0x2000    communication
-1    unlimited operation as authorizated user
(allows to manage user tokens)
http://sdk.pro.transcontrol.ru/wiki/en/sidebar/r … cess_flags
http://sdk.pro.transcontrol.ru/wiki/en/sidebar/r … rmat/token
Mobile Development
UniqueID
Re: UniqueID
Thank you so much!! I changed properties to generate token and its working!
UniqueID
(14/10/2015 01:18:10 отредактировано Desarrollo)
Re: UniqueID
Hello Kopa!!
I'm trying to get Messages by unit, but i don't know what is the best way tu use this method??
msj.loadInterval(id, from, to, 0, 0, Integer.MAX_VALUE, new MessagesResponseHandler()
I hope that you can explain.
Thanks
UniqueID
Re: UniqueID
Please see example for Remote API and example for Javascript SDK. Example for Java API will be a similar.
Mobile Development
