Bofan PT502
Тема: Bofan PT502
Hello everyone,
Kindly  anyone can help me on integrating Bofan PT502 vehicle tracker to  Wialon i have done everything as per the configuration from manufacturer but i cant get device online ,
I see on Device list its supported and around 100 registered on platform
http://gurtam.com/en/gps_tracking/gps_h … id=7406446
Kindly
Bofan PT502
Re: Bofan PT502
stevewangara
have you been able to set the proper APN and IP/port settings? Does your device accept and answer SMS-commands? Check the sim-card data availability and specify the unit ID to check logs on our end. Take a look at wires as well, try to test it outside with the proper power connection and GPS-availability.
Business Development Manager
Bofan PT502
Re: Bofan PT502
Hello
Yes i can get all the info
I have  done this now
000000SVR.212.98.173.204,20754 NOW
000000SVR,212.98.173.204,20754 before .
I have changed from Comma to Dot when setting up the Server was given as test device.
Regards
Steve
Bofan PT502
Re: Bofan PT502
stevewangara
Was it for Wialon Hosting? The right IP for the latter is 193.193.165.165.
Bofan PT502
Re: Bofan PT502
Hello
My device is working now
I used 000000SVR193.193.165.165
Before I was putting 000000SVR,193 or 000000SVR.193....
Many thanks
I am becoming expert day by day smile
Regards
Steve
Bofan PT502
Re: Bofan PT502
hi Steve,
i also recommend reading the Documents on http://docs.pro.transcontrol.ru/en/hosting/ regulary from the top to buttom a few times !
And if you have questions --> Forum :-)
Wolf.
Bofan PT502
Re: Bofan PT502
hello,
i have connected the pt502 on server and the communication was success.
the problem is with time interval for Sending GPRS Packet.
I have used the following commands :
000000GTI30,0,0,0,240
000000GTI30,0,0,0,0
000000GTI30,300,30,0,240
and doesn’t work.
I receive data only when i send the sms command or when I start the car.
The ignition sensor (yellow wire) is connected.
Does any one know what can be the problem?
