Adjustments for Right to Left Order Scripts/Languages
(08/12/2014 18:27:47 отредактировано Reza)
Тема: Adjustments for Right to Left Order Scripts/Languages
We have used "Localization Tool" to translate Wialon Hosting user interface for Persian(Farsi) language. The main issue for current version of  Wialon Hosting are as below:
1- Numbers still in form of Latin (English) and should be converted to Persian script.
2- When Persian words mix up with English words in a phrase, position of words will disorder in translated phrase and user can not recognize the target translation. This is very common because there are some units or abbreviations which we should keep in Latin (English) form.
3- The same problem exists for all other right to left  scripts like Arabic, Kurdish,.....
We think this enhancement should be of very high priority because number of customers and users of Wialon Hosting is increasing dramatically in middle east region.
Best regards
Reza Binesh
Reza Binesh
Technical Manager
Pishgaman Ertebat Hooshmand Co.
www.icpir.com, r_binesh@yahoo.com
Re: Adjustments for Right to Left Order Scripts/Languages
The first issue is clear. We will see what we can do about it.
Meanwhile, can you give a couple of examples on the second issue, so that we could see what you mean?
Katerina Alexandrova
Product Manager (Mobile)
(10/12/2014 16:26:37 отредактировано Reza)
Dear alek
Please see the attachment.
Иконка вложений Right to Left Adjustment.pdf 165.74 Кб, файл был скачан 854 раз(а)
Reza Binesh
Technical Manager
Thank you, Reza. Now I see what you mean.
We'll consider this case and I'll let you know about the result.
Reza , please check your e-mail and download the eclosed file.
We've done some inprovements to the translation tool and need your feedback.
The update for right-to-left scripts has been installed.
Those who are interested, please check the Localization Tool and Wialon itself.
