Ability to Maximize Apps Window
(06/04/2014 16:54:27 отредактировано JohnG)
Тема: Ability to Maximize Apps Window
Is it possible to have a  button on each of the Apps windows as standard in a future version. Currently the only way to maximize the window, which is needed to show all of the areas of the App, is to drag the window out. We should follow a set of application design standards that should be common across all applications that are to be used with Wialon, Gutram as well as partner developed. so there is a common look and feel as well as a common customer experience.
Phoenix Solusi
Mobile Visible Secure
Specialists in data acquisition and analysis for mobile and fixed assets. Integration in to content management systems is a specialty we have.
Re: Ability to Maximize Apps Window
JohnG Am I right, understanding your idea as a set of rights applied to all apps developers no matter whether it is Gurtam or someone from Partners Community?
JohnG when launching an app you can either start inside Wialon Hosting (click on the name) or in the new window (click on the icon)
as to the guidelines - it's a good idea, but first we should develop them in our own maps, be sure in them and than apply/recommend  them to the other apps developers. So not this year, i suppose.
In a shorter time we will share some key parts, like this panel
Try http://htoolz.pro.transcontrol.ru - here you can use MDI interface during working with apps.
(07/04/2014 19:07:08 отредактировано JohnG)
Yes the rights should be common to all applications but driven by Gurtam. This way the customer always experiences the same look and feel. Having reusable component would be a great start.
It will take some time to develop the framework but I think in the long run it will be very beneficial.
I tried to log into Toolz   but i got an authenmtication error. Is it the same as the Wialon hosting log in?
Phoenix Solusi
Opening the applications in a differnt window does what i wanted it to do. It would be good to have a help file with the applications. They are still awesome applications and can only get better.
Phoenix Solusi
JohnG пишет:
http://htoolz.pro.transcontrol.ru - yes
