what protocol is Wialon software using
Тема: what protocol is Wialon software using
We need to know the protocol type of the software so that we can connect our hardware with  Protocol that we  are using  are JT791/JT808 and JT1076/1078 protocol.
Can you please check and let us know?
We have dash camera with built in GPS, GPRS 4G/3G LTE, but need to know the protocol type to confirm if it can support the software you want to use.
Re: what protocol is Wialon software using
Wialon is a hardware-agnostic platform, supporting more than 3300 device types with diverse protocols.
If your device is using JT808 protocol, you can try pointing the equipment under the JT808 device type (port 22422):
https://pro.transcontrol.ru/en/gps-hardware/video/jt808
If you encounter any issues, please contact our support team via support@pro.transcontrol.ru.
Best regards,
Maria Valoshyna
Technical Care Engineer (L2 HW)
С уважением,
Мария Волошина
Technical Care Engineer (L2), HW Specialist
