Driver Login ApI
Тема: Driver Login ApI
We are developing the new mobile app for the drivers. Which API we have to use to login as driver using mobile number.
Driver Login ApI
Re: Driver Login ApI
https://hst-api.pro.transcontrol.ru/wialon/ajax.html?svc=resource/driver_operate&params={"phonenumber":"+919500502190","password":"******","callmode":"status"}
I am using the above request to driver login. but it's returning {error:1}
Driver Login ApI
Hello. Try to escape params according to application/x-www-form-urlencoded format, like:
https://hst-api.pro.transcontrol.ru/wialon/ajax.html?svc=resource%2Fdriver_operate&params=%7B%22phonenumber%22%3A%22%2B919500502190%22%2C%22password%22%3A%22******%22%2C%22callmode%22%3A%22status%22%7D
Driver Login ApI
Rual still no luck i am getting the same error. do we need to pass the sid for the api.
Driver Login ApI
(18/10/2019 17:30:32 отредактировано rual)
Sorry for previous wrong answer (was removed).
Your request is almost valid. Parameter names are case-sensitive, replace phonenumber with phoneNumber and callmode with callMode.
sid is required if callMode != status.
Driver Login ApI
rual  it's working perfectly. thumbs up mate.
