Estructure
Тема: Estructure
Hello
I have a client who wants to get information from the units. Downloading history.
But he wants to have a port enabled to the server to do this task.
Then you can make a structure to share that information. Whether in Excel, SQL, Json, XML. To share and make queries towards this information.
Can this task be done or should the client develop it?
What you do not want is to share your API because you see the word WIALON and it's something you do not want.
Do you have any ideas or insights?
Estructure
Re: Estructure
soporteCA, You can refer to this docs about retranslators: https://docs.pro.transcontrol.ru/en/hosting/cms/retra/retra
Estructure
Re: Estructure
Hello doel
What you want is that the client does not have to enable a port on your server to get the information.
What you want is to have access to read the information of the units. So a replicator is not what is needed.
Can you create a data structure for the client to have access to the information?
Enable a port on the server with the structure?
We are thinking about the API, but one problem we see is that it looks like WIALON and I want everything to be as transparent as possible with you.
Do you think that we can modify the API or mask for our DNS to appear?
Estructure
Re: Estructure
soporteCA, then use proxy.
