How to upload an app into account Gurtam?
Тема: How to upload an app into account Gurtam?
I'm developing an app with javascript and html for my account Gurtam but do not know how to upload my app and get permission from my account, because I doubt that if works just to get the token.
Can help me or suggest something, please?
(16/09/2016 09:15:55 отредактировано spev)
Re: How to upload an app into account Gurtam?
Hello.
You should use your own server to serve your app.
Note that your app should get authToken/authHash/sid from url parameter.
You can add your app to wialon from cms manager (https://docs.pro.transcontrol.ru/en/hosting/cms/apps/apps) or add possibility to auth in your app through login form (example: https://sdk.pro.transcontrol.ru/playground/demo/app_auth_token)
Telegram: Обновления Wialon, Wialon updates
Google Chrome Extensions: Wialon Units Map | Gurtam Forum Notifications | Wialon Apps Launcher
Evgenij Spitsyn, Developer, flespi team
spev
Sorry, I should use the three parameters ( authToken/authHash/sid ) from url or only one?
Thank you for the answer.
Denisse
Only one.
spev
Thank you very much for the answer.
Hi
Custom parameters as query string is possible or not in App
In my Javascript and html App i need to pass some more parameters other than the SID, AuthHash. Is it possible for me to do it.
Thanks in advance
J Prabhu
prabhu.janakiraman
Yes. You can use any parameters.
Hi Spev
Thanks for the reply. Can you share in which area of the app configurator i should add my custom parameters. I have attached the app configurator screen shot.
  • How to upload an app into account Gurtam?
J Prabhu
Hi
In Javascript API how to get the Custom fields of an Account using logged in users object.
I have attached the screenshot of the account custom fields
J Prabhu
(04/10/2016 16:52:32 отредактировано deal)
prabhu.janakiraman, to get user's account custom fields use such request:
var accountId = wialon.core.Session.getInstance().getCurrUser().getAccountId();
wialon.core.Session.getInstance().searchItems({itemsType:"avl_resource",propName:"sys_id",propValueMask:accountId,sortType:""}, 1, 137, 0, 0, function(code, data) {
console.log(data);
137 - flags:
0x00000001 - base flag
0x00000008 - custom fields
0x00000080 - administrative fields
Head of Wialon Local Department
prabhu.janakiraman, as for additional custom parameters - You can pass them to app.
Just set app URL in CMS Manager with Your parameters, for example:
http://my-dns.com/myapp.html?test=123&param2=ok
(04/10/2016 17:12:21 отредактировано prabhu.janakiraman)
It is working fine Thanks so much. But only after doing the below 2 steps only i get the custom fields as per your code logic. we should first load the custom fields library then we should update the session flags to fetch the customfields properties then if we call your code it is working fine.
var session = wialon.core.Session.getInstance();
session.loadLibrary("itemCustomFields");
var flags = wialon.item.Item.dataFlag.base | wialon.item.Item.dataFlag.billingProps | wialon.item.Item.dataFlag.customFields;
setupPayment.session.updateDataFlags( // load items to current session
                [{ type: "type", data: "avl_resource", flags: flags, mode: 0 }], // Items specification
                function (code) {
             //here we can have your code to get the custom fields data
J Prabhu
prabhu.janakiraman, if You use updateDataFlags there is no need to make additional requests (searchItems):
                function (code) {
var res = wialon.core.Session.getInstance().getItem(accountId);
var customFields = res.getCustomFields();
console.log(customFields);
Thanks deal . That is a valid point.
J Prabhu
Hi
I have a requirement to create a web service. There i need to create a login token using the user name and password through code. how can we achieve this?
J Prabhu
prabhu.janakiraman You can use "New authorization way" to log in and generate authToken/authHash/sid.
Examples:
https://sdk.pro.transcontrol.ru/playground/demo/advanced_form
Hi Spev
Thanks for the reply. I have checked those 2 urls. basically it asks for a login input. In my case i have my user name and password values as my paramters to a method from that methods i need to create a login token. without these login forms. Is there anyways available to achieve this?
J Prabhu
prabhu.janakiraman
No, we don't support this authorisation method.
HI
I am creating a geofence using remote api. In that remote api we have a itemId property. what value i need to pass to this propery. Also i have given my object below for your reference. I am getting error code 4.
  "itemId": 123****,
  "id": 0,
  "callMode": "create",
  "n": "SiteID1",
  "d": "Site Description",
  "t": 3,
  "w": 500,
  "f": 0,
  "c": 16733440,
  "tc": 0,
  "ts": 20,
  "min": 0,
  "max": 18,
  "libId": 0,
  "p": [
      "x": 27.516643322771575,
      "y": 53.910699370309359,
      "r": 500
J Prabhu
prabhu.janakiraman, pass in itemId parameter id of Your resource to create geofence in.
Hi
How to get the unit groups from an account in remote API?
J Prabhu
prabhu.janakiraman, is this theme http://forum.gurtam.com/viewtopic.php?id=10253 helpful for You?
Hi Deal
That is for Javascript API. Can you share any logic for the Remote API
J Prabhu
prabhu.janakiraman, using core/search_items request You can get all unit groups that current user has access to at once without getting update events:
https://hst-api.pro.transcontrol.ru/wialon/ajax.html?svc=core/search_items&params={"spec":{"itemsType":"avl_unit_group","propName":"sys_name","propValueMask":"*","sortType":""},"force":1,"flags":1,"from":0,"to":0}&sid=<your_sid>
To get unit groups from some certain account - just change parameters: "propName":"sys_billing_account_guid","propValueMask":"XX"
XX - account id
Thanks Deal it is working fine.
J Prabhu
Is there any way to run the web service on Wailon's server side?
infragmt, for now we don't host any third party applications or services on Wialon servers.
Ho to Get all UnitGroup Names for an Unit?
I am using Wialon Remote API. I would like to get all the Unit Group Names one unit belongs to.
Can anyone please help me on this.
J Prabhu
prabhu.janakiraman, is answered here https://forum.gurtam.com/viewtopic.php? … 62#p125962
I create an app to track unit and I use wialon javascript sdk (unit trace) when run app in debug mode the map appear but when run app in production mode the map does not appear. I don't know what is the problem.Please help me.
heba, what do you mean by debug or production mode of application? Provide code or give more details.
You can write private message.
